Jan 4, 2011, 5:40 a.m. EST
I cannot open your model in 4.1, there is an internal error in the geoemtrical decomposition, it seems too complex, or some pars are "almost touching", anyhow why all those layers ?
cannt you simply make a 1/4 shell an then add a slot as a few rectangles. Then you change the properties of the material.
Even I beleive you can make a virtual slot by using some bolean expressions in the material properties.
I always suggest to start ()very simple to get the model running and to be sure it's corect, then one can make it more realistic
furthermore I can only strongly suggest to get hands on the latest v4.1 patched as it works far more smoother than the 4.0
THere are more on this here
www.comsol.eu/support/knowledgebase/1089/
THere are more on this here http://www.comsol.eu/support/knowledgebase/1089/
Jan 5, 2011, 4:28 a.m. EST
Ivar, thank you for your reply. I use another method (extrude) to build the geometrical model and there is no error now. I do not know why. It is very weird. The final geometrical models are same. Fortunately the model is built yet.
Our software will be updated in a few days. Thank you for your suggestion.
Best regards.
Best regards.
