Property functions
I'm simulating a heat transfer that occurs in a material that goes through a phase change, so I need to change several boundary setting when this happens.
I probably have to to use the IF statement but not sure exactly how.
My simulation is from 900C down to 700C.
From 900C to 800C I have a function for each of these properties (all time dependent);
Thermal conductivity: f1(T)
Density: f2(T)
Heat Capacity: f3(T)
From 800 down to 700C I have 3 other functions for the above properties;
Thermal conductivity: f4(T)
Density: f5(T)
Heat Capacity: f6(T)
Is there a way to write both of these function in the property field with an IF syntax?
For example the density;
IF T>=800 f2(T)
IF T<800 f5(T)
Or do you use ELSE together with IF?
Thank you,
2 Replies Last Post Oct 14, 2016, 5:17 a.m. EDT
Posted: 9 years ago Oct 12, 2016, 8:11 a.m. EDT
Density: f2(T)
Density: f5(T)
IF T>=800 f2(T)
IF T<800 f5(T)
Thank you,
if(T>=800[degC],f2(T),f5(T))
Case sensitive.
[QUOTE] Hi, I'm simulating a heat transfer that occurs in a material that goes through a phase change, so I need to change several boundary setting when this happens. I probably have to to use the IF statement but not sure exactly how. My simulation is from 900C down to 700C. From 900C to 800C I have a function for each of these properties (all time dependent); Thermal conductivity: f1(T) Density: f2(T) Heat Capacity: f3(T) From 800 down to 700C I have 3 other functions for the above properties; Thermal conductivity: f4(T) Density: f5(T) Heat Capacity: f6(T) Is there a way to write both of these function in the property field with an IF syntax? For example the density; IF T>=800 f2(T) IF T=800[degC],f2(T),f5(T)) Case sensitive.
Posted: 9 years ago Oct 14, 2016, 5:17 a.m. EDT
Thank you for the reply, it works.
