avoid sharp picks _convergence problem
Dear All,
Do you have any idea how I can smooth this expression?
B=1/A*(A!=0)+0*(A==0)
Many thanks in advance,
Elham
2 Replies Last Post Jan 5, 2011, 12:31 p.m. EST
Posted: 1 decade ago Jan 5, 2011, 10:08 a.m. EST
have you tried
1/(A+eps)
if A is only >0 or only <0 it could work
or
if(A==0,0,1/A)
this might work
See the users Guide p81:
Use the if operator to avoid illegal operations. For example, if(x==0,1,sin(x)/x) is a valid and continuous expression for all values of x, including x = 0.
Hi have you tried 1/(A+eps) if A is only >0 or only
Posted: 1 decade ago Jan 5, 2011, 12:31 p.m. EST
Thank you ivar. what I've written and you suggest seem to be equivalant. apparantly, this kind of if condition shouldn't make convergence problem. I need to look for other sources of problem.
regards,
Elham
Thank you ivar. what I've written and you suggest seem to be equivalant. apparantly, this kind of if condition shouldn't make convergence problem. I need to look for other sources of problem. regards, Elham
