How to turn off deformation after a certain time in deformed geometry?
Posted Nov 3, 2016, 1:00 p.m. EDT Heat Transfer & Phase Change, Geometry, Materials, Structural Mechanics Version 4.2, Version 5.0 0 Replies
I have a question about the Deformed Mesh Interfaces. I was able to make a model, where I have linear translation of a hot solid object within a domain. The point is that I stop the deformation/the movement of the object at a certain time t and continue the simulation with the already deformed mesh. For this I used a piecewise function, which I multiplied with my function, defining the translation of the object. So I achieved the linear translation and the rest of the object (in the sense, that it stops and stay at the same point). The second option to do that was with a Boolean expression like if(t<5[s], velocity*time, stay at x=whatever). In both cases I can not get the solution to converge, because I get inverted mesh elements. So that is very unlogical, because through this two options, I actually stoped the movement and I see that all my boundaries don't move, but the mesh in between does. Can somebody help me out there, will really appreciate it!
Best regards
Antoni
Hello Antoni Artinov
