Linear extrusion and geometries with different dimensions
I have a question regarding linear extrusion. I have an irregularly shaped 2-D plate (from a CAD file), and I would like to couple it to a 3-D air space (ideally with a similar shape as the plate, but thicker). In 3.5a, one could just add another geometry (like in the tutorial model "Vibrations of a Disk Backed by an Air-Filled Cylinder"). It seems that in 4.0 one has to make two separate geometries and use linear extrusion. Am I correct? Is there a way of transforming my 2-D plate into 3-D with COMSOL?
Possibly, it might be easier to learn to use a CAD programme and plot the whole setup in 3-D..
Yours,
Henna
1 Reply Last Post Jan 17, 2011, 7:37 a.m. EST
Posted: 1 decade ago Jan 17, 2011, 7:37 a.m. EST
you are probably talking about the extrusion and revolve operation of the geometry. they are in v4.1 but might not be in 4.0
Hi you are probably talking about the extrusion and revolve operation of the geometry. they are in v4.1 but might not be in 4.0 -- Good luck Ivar
