Jan 18, 2011, 5:57 a.m. EST
if you have one mesh and it deforms all physics follow in my view, but if you have several meshes you might keep one stationary, check the solver geometry and mesh settings. In anycase that is typically worth a confirmation by support (and if possible relay it back here it's of general interest)
Jan 18, 2011, 2:15 p.m. EST
Thanks for the suggestion. I will post the updates if i amnage to figure it out.
Jan 18, 2011, 3:47 p.m. EST
Hi Ivar - Thanks again for your suggestion. It is commendable that you take care to answer most questions here on the forum. Hats off to you! I did confirm that the physics moves with the mesh. This means that the interface is physically moving along with all the equations. However i noticed that when i move the mesh, there are inverted meshes as a result of huge deformations. Is there any way around this, where i can still move my interface and not have inverted mesh elements. Quite frankly, this problem does not interfere with the solution and I wonder why the problem is notified in the first place. Thanks
Jan 18, 2011, 4:07 p.m. EST
indeed moving mesh is delicate for large deformations. There are several tricks, you can find some in th KB. The best is really to follow some of the COMSOL 1 day courses, there even one specifically for the advanced meshing such as ALE. Really it's more than a full days explanations. So start check and read the doc carefully (4.1, or 3.5a) on ALE and do some of the exercices from the model library. An inverted mesh here and there is not catastrophic, so long there are a few, normally COMSOL switches to linear shape function for these and manage to continue. There are also "remesh options", (was in 3.5a, havent tried nor know exactly where in v4.1, probably deep in the solver settings ;)
Oct 23, 2011, 9:37 p.m. EDT
Hi Melissa, Can you share your file? I am having similar problems.
