Stuck in calculation of Force
I downloaded a model that "Permanent Magnet Application ID: 78" and it's reated by COMSOL engineers. They used a compose model to decrease the computational time of the whole system. When I change the symmetry axis of the model, I'm able to obtain almost same force on the rod according to symmetry ratio that I applied. However, when I remove out the "compose" property and analyze the whole system once again, the obtained force is non-stable depending on block size(air) of the model. The obtained force should have been around 6.11 N but it's changing in the range of 3-8.3 (N) according to analysis result. Thus, could you please tell me what the point i missed and how to solve. And also, could you share the solved problem for whole system not for (1/4 model) ?
All the best
0 Replies Last Post Jan 7, 2017, 3:44 p.m. EST
Hello Yusuf Kahraman
