Dave Greve
Certified Consultant
8 years ago
Jan 9, 2017, 3:02 p.m. EST
It's hard to say without knowing more about the complete physical structure.
However- if the piezo is bonded to a metal- when the temperature increases the metal expands and will cause a stress in the piezo and hence a polarization. You would have to know thermal expansion coefficients for both materials to know how the signs work out.
DWGreve
DWGreve Consulting
DWGreve
DWGreve Consulting
8 years ago
Jan 9, 2017, 4:49 p.m. EST
Many thanks for your reply. The buzzer piezoelectric is bonded to a brass substrate and has a silver top electrode. The coefficient of thermal expansion for brass and silver is much greater than that of PZT and brass is about 60% stiffer than PZT so this should result in the PZT being 'stretched' along it's base resulting in an enhanced reduction in the spontaneous polarisation of the PZT due to the positive strain induced - even more than the result of the thermal expansion of PZT alone. After some thought I am thinking that the increase in polarisation I see is due to the heat source (a Peltier tile) heating the surface of the PZT in the centre only resulting in an expansion only in the 3-direction (perpendicular to the surface of the PZT) close to the surface which in the absence of heating within the PZT (that would cause a reduction in the spontaneous polarisation) would result in the polarisation increase. I'll try the experiment again and give the PZT longer to reach an even temperature. I doubt I will see any difference since the effect I've see is large - even placing a finger close to the silver electrode produces a considerable response! Thank you again for your thoughts.
Alan
Alan
