not converged in spite of the low error value
I'm modeling a reactor with turbulent fluid flow and heat transfer and got really confused. The Nonlinear
solver reaches the error value lower than 1e-10 however the solver dose not stop the calculation. Could any one assist me with this problem?
2 Replies Last Post Jan 26, 2017, 11:54 a.m. EST
Posted: 8 years ago Jan 24, 2017, 2:58 a.m. EST
There are several criteria which need to be fulfilled for a solution to be considered as converged.
Maybe the discussions in
www.comsol.com/community/forums/general/thread/35375
can be of some help.
Henrik
Hi, There are several criteria which need to be fulfilled for a solution to be considered as converged. Maybe the discussions in https://www.comsol.com/community/forums/general/thread/35375 can be of some help. Regards, Henrik
Posted: 8 years ago Jan 26, 2017, 11:54 a.m. EST
Hi ,
Dear Henrik,
Thank's for your reply.
I read that page and your explanation completely.
The damping factor for my case was descended.
I have three questions:
1- What should be done to prevent this happening ?
2- Does setting termination criteria to be "solution or residual" help solve this problem ?
3- I want to know what is the reason for the statement :
"it is required that the damping factor in the Newton solver is 1 before the solution is accepted"
Could you introduce some references for further study ?
Best regards
Michael Potter
Hi , Dear Henrik, Thank's for your reply. I read that page and your explanation completely. The damping factor for my case was descended. I have three questions: 1- What should be done to prevent this happening ? 2- Does setting termination criteria to be "solution or residual" help solve this problem ? 3- I want to know what is the reason for the statement : "it is required that the damping factor in the Newton solver is 1 before the solution is accepted" Could you introduce some references for further study ? Best regards Michael Potter
