poissons ratio of water
what value, we take for poissons ratio of water, because when we select water in comsol, ask for Young's Modulus, poissons ratio.
7 Replies Last Post Aug 4, 2017, 1:47 a.m. EDT
Posted: 8 years ago Feb 3, 2017, 9:47 a.m. EST
Hello Dinesh,
It sounds like you have a solid mechanics physics interface assigned to one or more domain that is filled with water. Make sure to correct that and the software won't expect a Poisson ratio for water.
Hello Dinesh, It sounds like you have a solid mechanics physics interface assigned to one or more domain that is filled with water. Make sure to correct that and the software won't expect a Poisson ratio for water. Jeff
Posted: 8 years ago Feb 4, 2017, 2:57 a.m. EST
how to change the physics, i am attaching the comsol file. please give the steps. i try to put comsol file in discussion forum but, it shows invalid file.​
Posted: 8 years ago Feb 13, 2017, 2:20 p.m. EST
You specify which domains a physics applies to in the selection list for that physics's top Model Builder node. See the Introduction to COMSOL Multiphysics manual, version 5.2a, around pages 114-120 for an example. All manuals are accessible through File>Help>Documentation.
You specify which domains a physics applies to in the selection list for that physics's top Model Builder node. See the Introduction to COMSOL Multiphysics manual, version 5.2a, around pages 114-120 for an example. All manuals are accessible through File>Help>Documentation. Best, Jeff
Posted: 8 years ago Jun 21, 2017, 12:46 a.m. EDT
But your suggestions don't help at all. I think you should give us more practical advice or find out the reason at least!Thanks !
[QUOTE] You specify which domains a physics applies to in the selection list for that physics's top Model Builder node. See the Introduction to COMSOL Multiphysics manual, version 5.2a, around pages 114-120 for an example. All manuals are accessible through File>Help>Documentation. Best, Jeff [/QUOTE] But your suggestions don't help at all. I think you should give us more practical advice or find out the reason at least!Thanks !
Posted: 8 years ago Jul 28, 2017, 8:50 p.m. EDT
Hello Jeff,
What if I want to use solid mechanics physics interface assigned to one or more domain that is filled with water. Then, what will be the value of Young's Modulus and Poisson's ratio?
Could we take Young's Modulus to be 2.2[GPa]?
One more thing, still I don't know the value of Poisson's ratio, could you please help me, I am trying to practice COMSOL tutorial Application ID: 417 ( Acoustic-Structure Interaction).
Thanks!
Hello Jeff, What if I want to use solid mechanics physics interface assigned to one or more domain that is filled with water. Then, what will be the value of Young's Modulus and Poisson's ratio? Could we take Young's Modulus to be 2.2[GPa]? One more thing, still I don't know the value of Poisson's ratio, could you please help me, I am trying to practice COMSOL tutorial Application ID: 417 ( Acoustic-Structure Interaction). Thanks!
Posted: 8 years ago Aug 2, 2017, 11:43 p.m. EDT
Updated: 8 years ago Aug 2, 2017, 11:44 p.m. EDT
You should not apply Solid Mechanics to a region that is occupied by water. To get fluid properties in solid mechanics you need a high bulk modulus (~2 GPa for water), and a shear modulus (and Young’s modulus) of zero. The model however will not be stable (mainly because the Lagrangian displacement-based solid mechanics formulation is not suitable for fluids). Instead use either a Fluid Flow Physics or an Acoustics Physics for the fluid.
Nagi Elabbasi
Veryst Engineering
You should not apply Solid Mechanics to a region that is occupied by water. To get fluid properties in solid mechanics you need a high bulk modulus (~2 GPa for water), and a shear modulus (and Young’s modulus) of zero. The model however will not be stable (mainly because the Lagrangian displacement-based solid mechanics formulation is not suitable for fluids). Instead use either a Fluid Flow Physics or an Acoustics Physics for the fluid. Nagi Elabbasi Veryst Engineering
Posted: 8 years ago Aug 4, 2017, 1:47 a.m. EDT
Thank you very much for your help.
