Channel with half water and air
I am new to COMSOL Multiphysics and want to model simple CFD channel already filled with half water and air. Also, water movement within the channel w.r.t air. Please guide me. Thank you.
1 Reply Last Post Feb 14, 2017, 3:21 a.m. EST
Posted: 7 years ago Feb 14, 2017, 3:21 a.m. EST
I think you would need to use the two-phase flow module. there are two options there: level-set or phase-field. both should work but read about their differences in the help:
www.comsol.com/model/capillary-filling-phase-field-method-1878
www.comsol.com/model/inkjet-nozzle-level-set-method-1445
you can also find these models under file-->aplication libraries
this blog post could be helpful too:
www.comsol.com/blogs/which-multiphase-flow-interface-should-i-use/
hope this helps
I think you would need to use the two-phase flow module. there are two options there: level-set or phase-field. both should work but read about their differences in the help: https://www.comsol.com/model/capillary-filling-phase-field-method-1878 https://www.comsol.com/model/inkjet-nozzle-level-set-method-1445 you can also find these models under file-->aplication libraries this blog post could be helpful too: https://www.comsol.com/blogs/which-multiphase-flow-interface-should-i-use/ hope this helps
