Unsaturated flow with dry initial condition
I am working with a Richards' equation model that tries to simulate an imbibition of a very dry soil.
As anyone can see, in literature it's reported that Richards' equation has not good convergence with initial dry condition, near to residual saturation value.
Actually, I have experienced that there is a thresh for the initial pressure head below which the solver doesn't converge.
In literature the problem is solved with the primary variable switching techique (using saturation as primary variable in unsaturated porous media) or controlling the steps of the solver modifying the preconditioner algorithm.
Can anybody give me some tips to emulate these procedures?
How can I customize the solver algorithm?
Thanks a lot!
Tommaso Santagata
2 Replies Last Post Mar 2, 2017, 2:34 p.m. EST
Posted: 7 years ago Feb 27, 2017, 7:34 a.m. EST
I have not tried switching. But some quick thoughts...
1. I also came across some years ago such a formulation wherein there is variable switching, but this was from the degree of saturation (or moisture content) to pressure as the primary variable; with pressure being switched on when Sr=1. But not from some initially dry state to some arbitrary unsaturated state.
2. If your problem is all about wetting a sample to saturation, do you need pressure as the primary variable? Just write a PDE for moisture diffusion or use some existing diffusion module, characterized by moisture diffusivity. Or a crude approach, which I don't like is to solve in one study step with moisture diffusion only and after the problem has reached certain sensible degree of saturation, solve another study step wherein you solve Richard's equation with the initial conditions based on study step 1, which will be in terms of degree of saturation, but can be converted to pressure via the moisture retention curve.
3. I think when you have really a dry state, you need to check the value of initial specific moisture capacity. What is it? Can it be fixed to some value that allows convergence.
4. In terms of elements, try linear elements, or in terms of solver, may be loosen up tolerance, there is also a knowledge base on solver settings for highly nonlinear problems, which you can search.
5. A final alternative could be to again use simple diffusion equation, but use density of vapour as the primary variable as in Chapter 7 of www.grs.de/sites/default/files/pdf/GRS-199_0.pdf
Suresh
Hi, I have not tried switching. But some quick thoughts... 1. I also came across some years ago such a formulation wherein there is variable switching, but this was from the degree of saturation (or moisture content) to pressure as the primary variable; with pressure being switched on when Sr=1. But not from some initially dry state to some arbitrary unsaturated state. 2. If your problem is all about wetting a sample to saturation, do you need pressure as the primary variable? Just write a PDE for moisture diffusion or use some existing diffusion module, characterized by moisture diffusivity. Or a crude approach, which I don't like is to solve in one study step with moisture diffusion only and after the problem has reached certain sensible degree of saturation, solve another study step wherein you solve Richard's equation with the initial conditions based on study step 1, which will be in terms of degree of saturation, but can be converted to pressure via the moisture retention curve. 3. I think when you have really a dry state, you need to check the value of initial specific moisture capacity. What is it? Can it be fixed to some value that allows convergence. 4. In terms of elements, try linear elements, or in terms of solver, may be loosen up tolerance, there is also a knowledge base on solver settings for highly nonlinear problems, which you can search. 5. A final alternative could be to again use simple diffusion equation, but use density of vapour as the primary variable as in Chapter 7 of https://www.grs.de/sites/default/files/pdf/GRS-199_0.pdf Suresh
Posted: 7 years ago Mar 2, 2017, 2:34 p.m. EST
Hi Suresh,
thank you for your accurate answer.
I succeded to perform my simulation implementing a constraint on effective saturation (dl.Se) writing in the box for the saturation expression:
if(dl.Se<=0,0,s_e)
where s_e is the effective saturation wrote in the variables table.
Actually, the problem was the negative value that saturation assumed during iterations: due to this, COMSOL couldn't find a value for relative permeability.
Anyway, let me replay to your comments:
1. Yes, that is exactly what I wanted to say: the primary variable switching technique (from pressure to saturation) is used when the saturation goes below 0.99-1. If you always use pressure as primary variable, more the pressure value (negative) goes down, more the oscillations of the solver occur. That's why I was talking about initially (very) dry condition, far from saturation condition and so difficut to solve with pressure as primary variable.
2. I would like to use pressure head as primary variable because it's the driving force of the phenomenon (I'm glad that I don't need to switch variable anymore!).
3. I'm using a function of liquid compressility:
(liquid compressibility) * (derivate of saturation respect to pressure head).
4. I'll try linear elements, while I'm solving with higly non linear settings, too.
5. Thank you very much for this reference.
Cheers!
Tommaso
Hi Suresh, thank you for your accurate answer. I succeded to perform my simulation implementing a constraint on effective saturation (dl.Se) writing in the box for the saturation expression: if(dl.Se
