Using analytical functions
I have a simple question. I am trying to use analytical functions in COMSOL. However, after I define my function in the model, I can't seem to access it if I put in a variable as the argument.
For instance, suppose that I define a function Cb = t. When I try to input Cb(t) as a term in the boundary conditions, it doesn't seem to work. However, if I say Cb(100), it seems to work, but it's not what I want. I want to be able to use Cb as a function of time.
Henry
3 Replies Last Post Feb 6, 2011, 2:52 a.m. EST
Posted: 1 decade ago Feb 5, 2011, 3:26 a.m. EST
how is your variable "t" defined ? Normally for COMSOL "t" is time and if you have no transient solver then t=0 by default.
Try to avoid single lettr variable names for private variables, most of these are already used internally by COMSOL
Unfortunately there is no build-in "variable name conflict help or "detector" " today
Hi how is your variable "t" defined ? Normally for COMSOL "t" is time and if you have no transient solver then t=0 by default. Try to avoid single lettr variable names for private variables, most of these are already used internally by COMSOL Unfortunately there is no build-in "variable name conflict help or "detector" " today -- Good luck Ivar
Posted: 1 decade ago Feb 5, 2011, 4:55 p.m. EST
Hi Ivar,
Yes, I'm trying to run a transient analysis, so "t" is referring to time in my problem. It's just that if I define a function and then try to to evaulate that function at time "t", it doesn't work.
For instance, suppose my function is Cb = t. If I try to access that function as "Cb(t)" in the boundary settings, it doesn't work. If I type in "Cb(100)" or something like that, it works. It I directly put in "t" in the boundary setting, it also works.
Do you have any idea why this is the case?
Henry
Hi Ivar, Yes, I'm trying to run a transient analysis, so "t" is referring to time in my problem. It's just that if I define a function and then try to to evaulate that function at time "t", it doesn't work. For instance, suppose my function is Cb = t. If I try to access that function as "Cb(t)" in the boundary settings, it doesn't work. If I type in "Cb(100)" or something like that, it works. It I directly put in "t" in the boundary setting, it also works. Do you have any idea why this is the case? Thanks, Henry
Posted: 1 decade ago Feb 6, 2011, 2:52 a.m. EST
what do you mean by not working ?
normally you should write Cb(t[1/s]) to avoid the "orange" unit errors, as operands are to be "unitless", but if "t" is defined = you are running a transient analysis it should work. Strange
Hi what do you mean by not working ? normally you should write Cb(t[1/s]) to avoid the "orange" unit errors, as operands are to be "unitless", but if "t" is defined = you are running a transient analysis it should work. Strange -- Good luck Ivar
