mphglobal with Matlab returning multiple values
Hi there,
I was using mphglobal successfully to pull parameters from my comsol model but now I have an issue. I made some changes to my model such as changing the mesh and adding some more variables and now when I try to pull out parameters with mphglobal it will return the value 41 times. So instead of returning a double, it returns a 41x1 array of identical doubles. Any idea what is going on?
Bryan
1 Reply Last Post Mar 15, 2017, 5:51 a.m. EDT
Posted: 8 years ago Mar 15, 2017, 5:51 a.m. EDT
If you have a time dependent model or a model that has a parametric sweep your global variables can take different values for different times/parameter values. I assume that is the case for your model.
You can use the function mphsolinfo to get information about the number of steps in your solutions.
Lars Gregersen
Comsol Denmark
Hi there,
Bryan
Hi If you have a time dependent model or a model that has a parametric sweep your global variables can take different values for different times/parameter values. I assume that is the case for your model. You can use the function mphsolinfo to get information about the number of steps in your solutions. -- Lars Gregersen Comsol Denmark [QUOTE] Hi there, I was using mphglobal successfully to pull parameters from my comsol model but now I have an issue. I made some changes to my model such as changing the mesh and adding some more variables and now when I try to pull out parameters with mphglobal it will return the value 41 times. So instead of returning a double, it returns a 41x1 array of identical doubles. Any idea what is going on? Thanks, Bryan [/QUOTE]
