importing from solid works
first of all hi ,
i am new to this so i could use all the help i could get .
i watched a tutorial of how to design a wind turbine to solidworks .
I try to import said geometry to comsol . The problem i face is that it is imported as one item thus , i cannot mess around afterwards with the materials etc.
I have thought of taking each part of the turbine and importing it piece by piece , but if you have a quicker solution , much appreciated
1 Reply Last Post Mar 21, 2017, 3:17 a.m. EDT
Posted: 8 years ago Mar 21, 2017, 3:17 a.m. EDT
By default, the final geometry operation is a "Form Union" operation. You need to change this to a "Form Assembly" operation, (change the setting within the Form Union node).
Mark
By default, the final geometry operation is a "Form Union" operation. You need to change this to a "Form Assembly" operation, (change the setting within the Form Union node). Mark
