AC/DC model: Matrix has zero on diagonal.
Hi everybody.
I have to calculate the magnetic field around three cables.
The model I built simply includes the three straight conductors and air around them.
A small voltage difference is applied and the Electric Currents module is first run to compute the current flowing in each conductor.
After that I run the Magnetic Felds module, but Comsol returns the following error message:
"Failed to find a solution.
Returned solution has not converged."
I'v done many attempts to solve the problem changing the mesh, the way model geometry is built, and even the type of solver, without success.
Could anyone suggest aternative approaches?
Massimo
4 Replies Last Post May 20, 2013, 4:31 a.m. EDT
Hello Massimo Bechis
Posted: 1 decade ago Apr 19, 2011, 1:59 p.m. EDT
I have this problem too.. Please help us to solve this error.
What part that we have to check and revise?
Chatra
I have this problem too.. Please help us to solve this error. What part that we have to check and revise? Regards, Chatra
Posted: 1 decade ago Apr 23, 2011, 8:23 a.m. EDT
why are you using those two physics, first of all the result from EC in your case is a constant current flow that you could easily enter directly into he MF, no need for the EC.
And if you really want to solve for both V and A, then use the MEF physics
There are some similar application names in 3.5
Hi why are you using those two physics, first of all the result from EC in your case is a constant current flow that you could easily enter directly into he MF, no need for the EC. And if you really want to solve for both V and A, then use the MEF physics There are some similar application names in 3.5 -- Good luck Ivar
Posted: 1 decade ago Nov 29, 2011, 9:29 a.m. EST
you can just change the conductivity of the air domain to some small finite value compared to the used copper.
Mladen
Hello, you can just change the conductivity of the air domain to some small finite value compared to the used copper. Best regards, Mladen
Posted: 1 decade ago May 20, 2013, 4:31 a.m. EDT
this method really works
