flow in porous media + heat and mass transfert
I have a 2D model where I want to model flow in porous media (Darcy's law), mass transfert (solute transport + diffusion) and heat transfert (convection and conduction). However, when I try to solve them both together, because they are coupled, I get this following message:
Error:
Undefined_value_found_Solvermodel
Undefined value found in the stiffness matrix.
There are 25 equations giving NaN/Inf in the matrix rows for the variable MB
at coordinates: (0.630536,0.00738895), (0.635249,0.00961293), (0.632893,0.00850094), (0.638481,0.00887769), (0.636865,0.00924531), ...
There are 25 equations giving NaN/Inf in the matrix rows for the variable T
There are 25 equations giving NaN/Inf in the matrix rows for the variable X
There are 25 equations giving NaN/Inf in the matrix rows for the variable rho_H2O
There are 25 equations giving NaN/Inf in the matrix rows for the variable rho_MS
There are 25 equations giving NaN/Inf in the matrix rows for the variable wCO2
There are 25 equations giving NaN/Inf in the matrix rows for the variable wO2
and similarly for the degrees of freedom, NaN/Inf in the matrix columns
What could the problem be ?
3 Replies Last Post Jan 13, 2012, 3:20 a.m. EST
Hello Joaquin
Posted: 1 decade ago Jan 12, 2012, 9:36 p.m. EST
I have the same problem. you have to check your intial and boundary conditions
Jamal
I have the same problem. you have to check your intial and boundary conditions Jamal
Mohamadreza Nassajian Moghadam
Posted: 1 decade ago Jan 13, 2012, 3:13 a.m. EST
I had exactly the same error when I modeled a poroelastic model. and I found that the problem was in material properties. I had a wrong magnitude for poisson ratio and when I changed it is was Ok. check material properties or boundary conditions.
Posted: 1 decade ago Jan 13, 2012, 3:20 a.m. EST
PS: how you did the coupling? because I want to model heat transfer in a porous media. but for that you should input the velocity of solute inside porous matrix.but for my model this velocity should be get form another poroelastic model which determine the velocity field inside matix when I apply cyclic presure on my system in each time step. that's why first I modeled a poroelastic model to calculate velocity field but I don't know how should I extract this velocity field in each time step and put it as a input for heat transfer model. in fact I don't know how to couple them!
