Variable static at zero
Hi. I had a similar problem a few weeks ago, but I believe this is different. Sorry if I'm spamming up the forum.
I'm trying to see how a function varies. Forgive my mess, but I've uploaded my defined variables here:
i.imgur.com/173NE53.png
The surface charge is a spatial function processed from Matlab and another model. This defines the fermi level. The fermi level defines the variable "W" and "omega0", but omega0 also has a W dependence, so the fermi level should essentially cancel.
A study sweeps through "w" which is different from W. w is an angular frequency. Strictly speaking the system sweeps through lam0 which is then converted to w just by w=2*pi*c/lam0 ..
Everything else is a constant.
You can see here that W varies with w as expected.
i.imgur.com/uE4Kytr.png
However, when I change the variable to omega0, there is a value of omega0=0 for all w. This surely shouldn't be the case?
i.imgur.com/NLWzl8X.png
I'm happy to answer any further questions anyone has.
Thanks in advance
0 Replies Last Post Apr 15, 2017, 7:32 p.m. EDT
Hello Joshua Viggiani
