2-way FSI model with automatic re-meshing stops with inverted mesh elements
Posted May 2, 2017, 12:35 p.m. EDT 2 Replies
Hello everyone,
I am trying to simulate the expansion of a filled magma chamber due to the injection of new magma (density= 2300 kg/m^3, dynamic viscosity= 1e5 Pa*s). I am interested in studying the flow of the magma in the chamber while it expands the chamber walls and deform the surrounding elastic material (Young´s modulus=30e9 Pa, density=2400 kg/m^3, and Poisson´s ratio=0.25).
This is a 2-way FSI problem. I am using an axisymmetric domain (see image) and the automatic re-meshing technique mainly to improve the mesh of the fluid of the magma chamber, subjected to a strong expansion.
The analysis always stops due to inverted mesh elements (the inverted element are those along the fluid-solid interface), no matter if I improve the mesh with smaller elements at the interface or if I increase the time steps. I reduced the tolerance to 0.0001, but doesn´t help. I can control the quality of the mesh by using the mesh quality as condition for re-meshing. I set the threshold for the minimum mesh quality at 0.5, but it doesn´t help. The solution doesn´t converge (and I still get inverted mesh elements) even if the mesh doesn´t look bad at all.
Does anyone have any idea about how to improve the model to solve this problem, or about what could be the reason for the elements' inversion?
Any help is very appreciated!
Thank you,
Erika
Thank you,
Erika
2 Replies Last Post May 4, 2017, 4:47 a.m. EDT
