Qn: Chemical reaction engineering module; setting viscosity of individual species
I'm using the Chemical reaction engineering module to model fluid flows with the TCS transport of concentrated species interface. Or the RFCS interface, reacting flow in porous media. I am attempting to use the chemistry interface to calculate the gas mixture properties.
I'm trying to use the chemistry interface to calculate the gas mixture properties; Specifically, the mixture dynamic viscosity, in addition to the thermal conductviity and heat capacity..
I can see how to get the specific heat capacity, and thermal conductivity of the mixture: I can enter a value for the property of each species, and then the software combines them into an effective mixture value.
But it seems impossible to get the dynamic viscosity (of a gas mixture without a solvent) unless I want to employ the relationships from kinetic gas theory (pg 51 of the user guide). I have the dynamic viscosity data of each species, relatively constant.
I would like to go to the individual species nodes and enter a (numerical) value for the dynamic viscosity of each gaseous species, but the software doesn't seem to want to let me do that..
I can see the variables defined in the [equation view] Chemistry node:
Its "chem.eta_speciesname1" and Its "chem.eta_speciesname2"
But I just can't see how to change / edit them?? Why COMSOL is so intent to block me from doing this? I can't seem to enter a user-defined value for the dynamic viscosity of the individual species...
0 Replies Last Post May 11, 2017, 10:27 p.m. EDT
Hello Russell Edwards
