Fluid Inlet
I want to show the inlet of fluid into multiple pipes placed in parallel to each other. I do not know how to select the inflow of fluid into the pipes. Because the pipe is hollow and I am not able to select the inlet face of the pipe.
2 Replies Last Post Jun 20, 2017, 11:13 p.m. EDT
Posted: 8 years ago Jun 20, 2017, 12:28 p.m. EDT
Hello Saurhab,
If I understand correctly, you are looking for the "Cap Faces" capability. See this thread where it was discussed: www.comsol.com/community/forums/general/thread/134711
Hello Saurhab, If I understand correctly, you are looking for the "Cap Faces" capability. See this thread where it was discussed: https://www.comsol.com/community/forums/general/thread/134711 Best, Jeff
Posted: 8 years ago Jun 20, 2017, 11:13 p.m. EDT
Thanks a lot. I shall try that and will see if that helps.
Saurabh
Thanks a lot. I shall try that and will see if that helps. Saurabh
