Nov 9, 2009, 4:48 p.m. EST
Hi I have same problem. Did you find any solution for that? Please let me know.
Aram
Aram
Oct 14, 2010, 2:13 a.m. EDT
I have the same problem as you had faced. Will you please tell me, how did you solve it ?
Thanks in advance,
Kiran
Thanks in advance,
Kiran
Jan 26, 2011, 6:06 p.m. EST
Hi!
I have a question on the Acoustics module in Comsol, regarding how to set a monopole acoustic source.
I have a point acoustic source characterized by a modulated sin wave:
In Matlab coding,
y=-sin(2.*pi.*Freq.*Ts).*hanning(length(Ts))'
Here, the acoustic source is described in terms of particle displacement, y.
However, I understand that in Comsol, to set a point source, we are supposed to go to Physics > Point settings > Pressure acoustics, and select the type of source as flow, intensity and power.
My question is, how do we convert the description of the point source from displacement to a description in terms of either flow, intensity or power?
Thanks!
Hi.
Have you figured out how to do yet? Thanks~
[QUOTE]
Hi!
In Matlab coding,
Thanks!
[/QUOTE]
Hi.
Jun 4, 2011, 10:54 p.m. EDT
i have the similar question for setting the dipole source
Sep 8, 2011, 5:24 p.m. EDT
Have you figured out the problem yet?
Mads Herring Jensen
COMSOL Employee
Sep 13, 2011, 4:54 a.m. EDT
Hi all
When entering a flow point source in the frequency domain, the source amplitude S has the dimension m^3/s. In order to set the "radial displacement" U0 of the source you can enter S = U0*acpr.iomega*4*pi.
Best regards
Mads
Hi all
Best regards
Mads
Feb 4, 2012, 4:09 a.m. EST
I too have a problem in something related to the above discussion. If anyone can explain how COMSOL solves the point source problems. The documentation doesn't explain much..
Jul 31, 2014, 3:13 a.m. EDT
Then how I can set Q in the monopole source whose dimension is 1/s^2 in 2D.
