Magnetic Poles
Posted Jun 28, 2017, 12:42 a.m. EDT 0 Replies
I modeled magnet using magnetization of the solid but the result is not good. I want to calculate the force between 2 magnets connected in parallel with a gap distance, having the same poles. I used magnetization of the 2 solids having positive and negative value of magnetization along the axis; meaning same pole facing each other, but the result is not good. Changing the sign to be the same did not give a good result as well. How can i use magnetization value to model north and south pole
Hello Oyelade Akintoye
