Hello Muhale Mutshena
Feb 27, 2012, 10:04 p.m. EST
Did you find a solution for this? I too get the same error.
Feb 28, 2012, 1:20 a.m. EST
try a EDIT clear all solution Edit Clear Mesh, File Reset Model, save, reopen COMSOl clean and reload your file. This might do the trick
Feb 28, 2012, 1:31 p.m. EST
Hi Ivar, i have the same problem, but with your answer I erased the solution, so, this is not the best way to solve this problem...another idea?
Feb 29, 2012, 12:52 a.m. EST
sorry to hea that, but indeed if you delete a solver you delete the related nodes lower down. The best would be to use a newer veersion of COMSOL 4.0 was really the firs out in the new "costume", the stability of the programme has greatly improved since
Nov 6, 2012, 8:03 a.m. EST
Hi all,
it happened after i copy comsol model 4.2 (incl. solution) to another directory.
i'm not sure about it but it can be "reproduced" or "repaired" by send that model to comsol support via some ftp link.
regards
akmal
Hi all,
regards
akmal
