smoothing a parameter distribution
Michael Rembe Certified Consultant
in a Darcy flow problem there is a very hard step between the distribution of two parameter quantities (k=1e-8m²/1e-12m²). This causes numerical problems.
Has anybody a good idea how to smooth the transition? Is there a way using a pde to smooth the transition over a given interface thickness in a first stationary simulation step (comparable with the interface thickness of the level set method)?
I could use a transient pde and smooth by diffusion. But I don't want to get a time dependent problem.
Thank you very much!
Best regards
Michael
2 Replies Last Post Jul 12, 2017, 8:26 a.m. EDT
Posted: 8 years ago Jul 12, 2017, 8:06 a.m. EDT
Hello Michael,
If the interface between the two domains has a relatively simple shape you could simply explicitly prescribe a spatially-dependent function (based on the step function that is pre-implemented for you in the software, or not).
If on the other hand the interface between the two domains has a complex shape and it's not possible to find an explicit function, the following blog post might help:
www.comsol.com/blogs/tips-using-wall-distance-interface/
Hello Michael, If the interface between the two domains has a relatively simple shape you could simply explicitly prescribe a spatially-dependent function (based on the step function that is pre-implemented for you in the software, or not). If on the other hand the interface between the two domains has a complex shape and it's not possible to find an explicit function, the following blog post might help: https://www.comsol.com/blogs/tips-using-wall-distance-interface/ Best, Jeff
Posted: 8 years ago Jul 12, 2017, 8:26 a.m. EDT
Hello Jeff,
using the wall distance interface is a very good idea, because it is a complex geometry! Thanks a lot!!
Best regards
Michael
Hello Jeff, using the wall distance interface is a very good idea, because it is a complex geometry! Thanks a lot!! Best regards Michael
