How to implement the Beer-Lambert absorption law when ablating a solid.
I have a model which I am heating with a laser heat source.
The laser is absorbed in the solid according to Beer's law, that is the intensity of the radiation exponentially decays with path length, [ exp(-alpha*x) ] where x is path length.
This all works fine.
I am trying to implement albation in my model.
When the temperature goes above the vaporization temperature the material is 'ablated'.
My problem is that Beer's law scales with x so that it starts at x = 0 even when part of the material is ablated the equation still scales from x=0.
Basically I need to redefine my coordinate x as the ablated region moves across the material so that x starts at zero and increases linearly.
I have tried using a condition (T>300)*x where 300 is the vaporization temperature.
This condition works in that the x is zero up until the edge of the ablated region but then x jumps to whatever value it had before i.e it doesn't scale linearly.
If anyone has any information that might help me I'd really appreciate you letting me know.
Sorry if the explanation is extremely confusing!
-Adam
1 Reply Last Post Apr 15, 2014, 11:12 a.m. EDT
Hello Adam Collins
Posted: 1 decade ago Apr 15, 2014, 11:12 a.m. EDT
Hi Adam,
i wonder if maybe you got your problem solved and if you still know the solution as well. In this case, could you please tell me what you have done? That would be awesome.
Regards
Steffen
Hi Adam, i wonder if maybe you got your problem solved and if you still know the solution as well. In this case, could you please tell me what you have done? That would be awesome. Regards Steffen
