negative concentration at surface
i am modeling a laminar flow through a small channel with a surface reaction taking place on a small surface of one of the walls. This wall has an initial reactant B on it, which should be converted to product C through a reaction with reactant A introduced through the laminar flow.
The problem with this model is that the concentration of B on the surface can reach negative concentration. (which is equal to the concentration of C on the surface going over the initial concentration of B). even though i have set a number of maximum available sites on the surface, which is the same number as initial reactant B on this surface.
Is there a way to fix this problem?
i am using the chemistry, laminar flow, transport of diluted species and surface reaction modules for this.
concentrations are in the order of 10^-7. pressure is around 1 atm, fluid velocity is 2.5e-4 m/s.
I have tried different time steps for the solver, the danckwerts flux, ramp up the concentration from the initial start instead of a set concentration but none of these worked.
Only increasing my concentrations by a few orders of magnitude and decreasing my reaction rates to unrealistic values led me to a solution where the concentration of B didn't fall below zero and was limited to 0.
12 Replies Last Post Jul 27, 2017, 6:31 p.m. EDT
Posted: 7 years ago Jul 26, 2017, 7:30 p.m. EDT
If your reaction rate is R, set R=max(eps^2,R). This should probably solve your issue.
Posted: 7 years ago Jul 26, 2017, 9:38 p.m. EDT
Where is the negative concentration located?
Posted: 7 years ago Jul 27, 2017, 1:41 a.m. EDT
Updated: 7 years ago Jul 27, 2017, 1:43 a.m. EDT
where can i set this?
should it be inserted into the reaction rate equation or can it be set as a parameter?
[QUOTE] If your reaction rate is R, set R=max(eps^2,R). This should probably solve your issue. [/QUOTE] where can i set this? should it be inserted into the reaction rate equation or can it be set as a parameter?
Posted: 7 years ago Jul 27, 2017, 1:42 a.m. EDT
the negative concentration is located on the surface where the reaction happens.
On the rest of the domain the concentration remains positive and physically feasible.
[QUOTE] Where is the negative concentration located? [/QUOTE] the negative concentration is located on the surface where the reaction happens. On the rest of the domain the concentration remains positive and physically feasible.
Posted: 7 years ago Jul 27, 2017, 8:53 a.m. EDT
So the WHOLE surface has negative concentration?
[QUOTE] [QUOTE] Where is the negative concentration located? [/QUOTE] the negative concentration is located on the surface where the reaction happens. On the rest of the domain the concentration remains positive and physically feasible. [/QUOTE] So the WHOLE surface has negative concentration?
Posted: 7 years ago Jul 27, 2017, 11:42 a.m. EDT
No,it starts at the edge of the reaction surface, but as time increases a greater portion of the surface reaches a negative concentration. I've included a picture of the domain i'm talking about.
i've tried refining the mesh from extra course to finer, and decreasing the initial step size of the solver to 1e-10 but it gave the same results.
[QUOTE] [QUOTE] [QUOTE] Where is the negative concentration located? [/QUOTE] the negative concentration is located on the surface where the reaction happens. On the rest of the domain the concentration remains positive and physically feasible. [/QUOTE] So the WHOLE surface has negative concentration? [/QUOTE] No,it starts at the edge of the reaction surface, but as time increases a greater portion of the surface reaches a negative concentration. I've included a picture of the domain i'm talking about. i've tried refining the mesh from extra course to finer, and decreasing the initial step size of the solver to 1e-10 but it gave the same results.
Posted: 7 years ago Jul 27, 2017, 11:50 a.m. EDT
Can you also plot the concentration of A on the surface as well?
[QUOTE] [QUOTE] [QUOTE] [QUOTE] Where is the negative concentration located? [/QUOTE] the negative concentration is located on the surface where the reaction happens. On the rest of the domain the concentration remains positive and physically feasible. [/QUOTE] So the WHOLE surface has negative concentration? [/QUOTE] No,it starts at the edge of the reaction surface, but as time increases a greater portion of the surface reaches a negative concentration. I've included a picture of the domain i'm talking about. i've tried refining the mesh from extra course to finer, and decreasing the initial step size of the solver to 1e-10 but it gave the same results. [/QUOTE] Can you also plot the concentration of A on the surface as well?
Posted: 7 years ago Jul 27, 2017, 12:02 p.m. EDT
Updated: 7 years ago Jul 27, 2017, 12:09 p.m. EDT
here are the plots of concentration AB on the surface. and Concentration A along the surface. (although last one is taken from the transport of diluted species data because A is not a surface species.) i also included the contour plot of the concentration of A inside the domain, which i never see falling below 0.
[QUOTE] [QUOTE] [QUOTE] [QUOTE] [QUOTE] Where is the negative concentration located? [/QUOTE] the negative concentration is located on the surface where the reaction happens. On the rest of the domain the concentration remains positive and physically feasible. [/QUOTE] So the WHOLE surface has negative concentration? [/QUOTE] No,it starts at the edge of the reaction surface, but as time increases a greater portion of the surface reaches a negative concentration. I've included a picture of the domain i'm talking about. i've tried refining the mesh from extra course to finer, and decreasing the initial step size of the solver to 1e-10 but it gave the same results. [/QUOTE] Can you also plot the concentration of A on the surface as well? [/QUOTE] here are the plots of concentration AB on the surface. and Concentration A along the surface. (although last one is taken from the transport of diluted species data because A is not a surface species.) i also included the contour plot of the concentration of A inside the domain, which i never see falling below 0.
Posted: 7 years ago Jul 27, 2017, 12:32 p.m. EDT
Sorry man, I am stumped. With your B concentration going negative, you should have a negative reaction rate, which should cause the generation of species A instead of consumption. But your A contour plot looks perfectly normal.
[QUOTE] [QUOTE] [QUOTE] [QUOTE] [QUOTE] [QUOTE] Where is the negative concentration located? [/QUOTE] the negative concentration is located on the surface where the reaction happens. On the rest of the domain the concentration remains positive and physically feasible. [/QUOTE] So the WHOLE surface has negative concentration? [/QUOTE] No,it starts at the edge of the reaction surface, but as time increases a greater portion of the surface reaches a negative concentration. I've included a picture of the domain i'm talking about. i've tried refining the mesh from extra course to finer, and decreasing the initial step size of the solver to 1e-10 but it gave the same results. [/QUOTE] Can you also plot the concentration of A on the surface as well? [/QUOTE] here are the plots of concentration AB on the surface. and Concentration A along the surface. (although last one is taken from the transport of diluted species data because A is not a surface species.) i also included the contour plot of the concentration of A inside the domain, which i never see falling below 0. [/QUOTE] Sorry man, I am stumped. With your B concentration going negative, you should have a negative reaction rate, which should cause the generation of species A instead of consumption. But your A contour plot looks perfectly normal.
Posted: 7 years ago Jul 27, 2017, 5:19 p.m. EDT
Just put "max(eps^2, R)" where you would put the user defined reaction rate. With R being your actual reaction rate. This should fix the issue.
Posted: 7 years ago Jul 27, 2017, 5:53 p.m. EDT
Updated: 7 years ago Jul 27, 2017, 5:55 p.m. EDT
thanks! i've put the term around my reaction rate term of the species which went negative in concentration. It seems to have fixed the issue!
[QUOTE] Just put "max(eps^2, R)" where you would put the user defined reaction rate. With R being your actual reaction rate. This should fix the issue. [/QUOTE] thanks! i've put the term around my reaction rate term of the species which went negative in concentration. It seems to have fixed the issue!
Posted: 7 years ago Jul 27, 2017, 6:31 p.m. EDT
glad I could help
glad I could help
