How to Simulate Magnetostatic without Singular matrix error
I want to simulate Magnetostatic type to applied to DC Magnetron Sputter.
So, I modeled Permanent magnet, Yoke, Back-Plate, Target which are made of DC Magnetron Sputter.
then, i did it as below
1. I insert input value according to each material (Permanent Magnet-0.4Tesla, BackPlate-Copper, Target, Yoke - Aluminum).
2. In magnetic Fields, No Currents(mfnc), i set to Magnetic Flux conversion and Zero Magnetic Scalar Potential only.
3. In mesh, i click the Extremely fine in Free Tetrahedral.
4. Finally, In Study tab, I clear check box of "generate default plots" (this is imitate of tutorial file of "Permanent Magnet" provided from COMSOL website).
in this, the error "Singular matrix" is generated and i don't know how to solve it.
Please help how i do.
1 Reply Last Post Aug 10, 2017, 5:10 a.m. EDT
Posted: 7 years ago Aug 10, 2017, 5:10 a.m. EDT
Have you included an air (or vacuum) domain surrounding your magnetron? This is required for electromagnetic problems in order to create a finite region within which the problem can be solved.
Mark
Have you included an air (or vacuum) domain surrounding your magnetron? This is required for electromagnetic problems in order to create a finite region within which the problem can be solved. Mark
