Mar 14, 2011, 8:03 a.m. EDT
In the definition node you define an "operator" that applies to something you define elsewhere. In the definition you only specify entities where it applies and integration information (this is different from v3.5 now its a two step operation, and you first define an operator then afterwards the variable(s) even several with the same operator)
In your case you need to define a global (or model or entity local) variable E = intop1(spf.U^2) or whatever you want in there.
Note: in 2D-axi you might want to add the 2*pi*r to integrate over the volume, all depends on what you want to do, or you want to multiply by the entity density, in which case DO IT INSIDE THE INTEGRATION () because your density is not really uniquely define outside an entity scope, as it might change from entity to entity
The result is a scalar, for a transient analysis or a parametric sweep it becomes a vector, you need to select "at()" which time you want the output via the general time/parameter selection tab in the results window
Mar 14, 2011, 8:20 a.m. EDT
Many thanks. All clear now.
Leon
Leon
Mar 28, 2012, 5:40 a.m. EDT
Hi.
I have a somewhat related problem:
on a whole 3D (x, y, z) domain, I want to define a value f(x)=integral over y and z of k(x,y,z)
With k beeing my turbulent cinetic energy.
How can I do this?
Hi.
How can I do this?
Jan 3, 2013, 4:04 a.m. EST
I am using one integration coupling variable in my problem that couples General form PDE with solid mechanics module. When I select "Integration" as the method for this coupling variable, the problem hits the maximum memory (around 20GB) and ends the solution with an "out of memory" error. However, when I select "Summation over nodes" as the method, the solution works with around 1.5GB memory. Do you have any explanation for this difference?
Jan 3, 2013, 5:28 a.m. EST
that can also depend on what expression you use in your variable based on the integration you defined.
Normally COMSOL takes care itself to use the "right one" but if you mix a "summation" internal variable and an "integration" one, COMSOL might get fooled
Jan 3, 2013, 5:57 a.m. EST
hello,
The expressions are the same. I only changed the method. The method "summation over nodes" worked well while the method "integration" crashed.
Thank you,
Onur S. Aslan
hello,
Thank you,
Onur S. Aslan
Jan 3, 2013, 6:05 a.m. EST
Indeed but what are you expressions ?
as some of the internal COMSOL variables require "summation over nodes" (mainly reaction forces variables), other use the interpolated "integration" way, and if you mix both type of variables in an expression I'm not what COMSOL tries out ;)
check the doc for the given variables
And check also the units, summation and integration dos not have the same effect here
sometimes it could be also a frame issue, but normally the default settings are OK
