Plot z=(x,y) in COMSOL
NDN UNIST/Mechanical Engineering
Dear all
Does anyone know how to make a plot z=(x,y) in comsol ?
I need to make this plot to evaluate my design
Best regards
1 Reply Last Post Sep 5, 2017, 7:47 a.m. EDT
Posted: 7 years ago Sep 5, 2017, 7:47 a.m. EDT
You can add a Height Expression to a standard surface plot in your results, (make sure mesh and cut-plane resolution are sufficient for your needs). See attached example. I am not sure if the Height Expression capability is available in version 4.3...
An analytical surface plot can be created if that is what you need (see attached).
Hope this helps,
Mark
You can add a Height Expression to a standard surface plot in your results, (make sure mesh and cut-plane resolution are sufficient for your needs). See attached example. I am not sure if the Height Expression capability is available in version 4.3... An analytical surface plot can be created if that is what you need (see attached). Hope this helps, Mark
