Heat exchanger, failed to evaluate variable
I'm trying to model two counterflowing fluids (water and steam), which exchange heat through a copper surface. I'm using General Heat Transfer and Incompressible Navier-Stokes modules.
I've set up inlets and outlets in the N-S module and constant temperatures and convective fluxes in the heat transfer module. I've been messing with many settings and I may be close to solution, but now I'm getting the error:
Failed to evaluate variable U_ns
Geometry 1
Dimension 2
Domains{2}
I can't figure out what that variable is and how I could fix it. In Physics->Equation systems->Subdomain Settings I found a list of variables that has U_chns, but not U_ns. Even if it was there I wouldn't know what to do. Any ideas? I've attached the file (from COMSOL 3.4).
2 Replies Last Post Mar 22, 2011, 9:49 a.m. EDT
Posted: 1 decade ago Mar 21, 2011, 10:51 a.m. EDT
3.5 is too old for my versions, but is you are in "chns" and get a variable name of "ns", there must be something messed up. You should either check the underlaying equations or redo your model from fresh
Hi 3.5 is too old for my versions, but is you are in "chns" and get a variable name of "ns", there must be something messed up. You should either check the underlaying equations or redo your model from fresh -- Good luck Ivar
Posted: 1 decade ago Mar 22, 2011, 9:49 a.m. EDT
Alright. I rebuilt the model and still got singular matrix errors like before. I finally managed to get a solution when I inserted better initial values for temperature. Still don't understand what that weird constant was, but now it's working. Thanks.
