Export Parametric Sweep Solutions as Columns in Single File
Hi guys,
I am using the solid mechanics module to analyse the deformation on a surface due to a boundary load from a 'point' source (a Mogi model), with a stationary solver. Please see attached file.
I can create a plot of the values of an expression at set intervals along the surface - in this case using an Edge 2D data set, and the w expression (displacement field, Z component). I can export this data fine, however I encounter problems when I carry out a parametric sweep - as I cannot export the data as I would like.
I can very any of my parameters using the sweep, and produce the same plot as before (but with data pertaining to each stage of the sweep). However, when I come to export this Edge 2D data set with the Parametric solutions selected, I can only export one parameter value at a time.
I am looking to export all of my parameter values at set intervals along the surface, in separate columns - such that I can inspect/compare them and import the data into other programs with ease.
Is there a way to do this? Am I using the wrong approach?
Thanks for any help you can offer.
3 Replies Last Post Jan 3, 2018, 3:38 a.m. EST
Posted: 7 years ago Oct 31, 2017, 3:29 a.m. EDT
Hi Matthew,
This isn't possible in 5.2a, but it has been implemented in 5.3, so I suggest that you upgrade to 5.3
Hi Matthew, This isn't possible in 5.2a, but it has been implemented in 5.3, so I suggest that you upgrade to 5.3
Posted: 7 years ago Jan 2, 2018, 8:56 p.m. EST
Hi Matthew,
I tried with 5.3 and nothing changes. Can you please explain how export plot?
Thank you.
>Hi Matthew, > >This isn't possible in 5.2a, but it has been implemented in 5.3, so I suggest that you upgrade to 5.3 I tried with 5.3 and nothing changes. Can you please explain how export plot? Thank you.
Posted: 7 years ago Jan 3, 2018, 3:38 a.m. EST
Updated: 7 years ago Jan 3, 2018, 3:39 a.m. EST
Hi Matthew,
Thank you.
That's strange. The following steps work for me:
  • Start 5.3.0.223.
  • Open the BasicBenchmark.mph model that Matthew attached.
  • Compute Study 1.
  • Select Results > Export > Data 1.
  • Change the selection in the Parameter values (d,a,P,Pois) list to all tuples.
  • Browse to a filename.
  • Export.
Maybe your use case differs from Matthew's.
>>Hi Matthew, >> >>This isn't possible in 5.2a, but it has been implemented in 5.3, so I suggest that you upgrade to 5.3 > >I tried with 5.3 and nothing changes. Can you please explain how export plot? > >Thank you. That's strange. The following steps work for me: - Start 5.3.0.223. - Open the BasicBenchmark.mph model that Matthew attached. - Compute Study 1. - Select Results > Export > Data 1. - Change the selection in the Parameter values (d,a,P,Pois) list to all tuples. - Browse to a filename. - Export. Maybe your use case differs from Matthew's.
