Jeff Hiller
COMSOL Employee
7 years ago
Nov 27, 2017, 9:25 a.m. EST
Updated:
7 years ago
Nov 27, 2017, 10:17 a.m. EST
Hello Hossein,
In some cases, the solution of a PDE is independent of the material properties.
In your case, it sounds like you're solving the steady-state electric currents equation with a spatially-independent conductivity , and with your boundary conditions being all Dirichlet or zero flux. In that case, you can see that , the conductivity, is the only material property that appears in the equation and the BCs, and that it can actually be removed from the equation (because is spatially-independent and can therefore be taken out of the divergence and eliminated from the equation by dividing both sides by ) and the BCs (by dividing both sides of those BCs by ).
PS: While in your model the voltage and electric potential (which is defined solely in terms of the voltage) do not depend on , some other quantities do, for instance the current density.
Jeff Hiller
Hello Hossein,
In your case, it sounds like you're solving the steady-state electric currents equation with a spatially-independent conductivity \sigma, and with your boundary conditions being all Dirichlet or zero flux. In that case, you can see that \sigma, the conductivity, is the only material property that appears in the equation and the BCs, and that it can actually be removed from the equation (because \sigma is spatially-independent and can therefore be taken out of the divergence and eliminated from the equation by dividing both sides by \sigma) and the BCs (by dividing both sides of those BCs by \sigma).
PS: While in your model the voltage and electric potential (which is defined solely in terms of the voltage) do not depend on \sigma, some other quantities do, for instance the current density.
7 years ago
Feb 20, 2018, 2:59 p.m. EST
Updated:
7 years ago
Feb 21, 2018, 2:05 a.m. EST
Hi, I also have been working on Elictric current intreface. In my model three materials were used. I have attached a schematic diagram, which describes the whole procedure. Where dark circles are copper elctrode. First Result is obtained for perticular dielectric properties (permittivity & conductivity) for material 1 and material 2. Second result is obtained done for different properties of material 2, while other material remain same. Both simulation done under frequency domain. But contribution (current density & electric field) of material 1 is different for 2nd result. What is the reason for that?
Thanks in advance.
Thanks in advance.
