Phase animation in COMSOL 4.1
Is it possible to get a phase animated plot of a RF solution in COMSOL 4.1?
Thanks.
6 Replies Last Post Feb 8, 2012, 10:25 a.m. EST
Posted: 1 decade ago Mar 30, 2011, 11:11 a.m. EDT
you have the arg() function or atan2(imag(yourVariable),real(yourVariable)) way, or via a table defined in the postprocessing Defined Variable node
Hi you have the arg() function or atan2(imag(yourVariable),real(yourVariable)) way, or via a table defined in the postprocessing Defined Variable node -- Good luck Ivar
Posted: 1 decade ago Mar 31, 2011, 8:29 a.m. EDT
Thanks Ivar. I'm not really sure on how to do that. I have solved a RF model in the frequency domain and I can use the "player" feature of 4.1 to animate the solution in a frequency sweep, but I cannot animate the solution changing the phase (solution at angle) for a fixed frequency. Where should I use the functions that you say?
Iker.
Thanks Ivar. I'm not really sure on how to do that. I have solved a RF model in the frequency domain and I can use the "player" feature of 4.1 to animate the solution in a frequency sweep, but I cannot animate the solution changing the phase (solution at angle) for a fixed frequency. Where should I use the functions that you say? Regards, Iker.
Posted: 1 decade ago Apr 1, 2011, 2:41 a.m. EDT
Hello!
You have to change the player setting for "sweep type" to "dynamic data extension".
This will work, if your variable is something like V = Vmax*exp(j) for complex calculation.
Ralf
Hello! You have to change the player setting for "sweep type" to "dynamic data extension". This will work, if your variable is something like V = Vmax*exp(j) for complex calculation. Ralf
Posted: 1 decade ago Feb 7, 2012, 4:50 p.m. EST
Are there any better instructions for doing RF phase animations? The instructions in this thread are too terse for me to understand.
Posted: 1 decade ago Feb 8, 2012, 9:25 a.m. EST
Hi!
One example...but for MEF.
Ralf
Hi! One example...but for MEF. Ralf
Posted: 1 decade ago Feb 8, 2012, 10:25 a.m. EST
Hi Ralf,
this is something I had been looking for for a while. Thanks a lot and my vote for you.
Cheers
Edgar
P.S. Just wondering how they define their terminolgy at COMSOL. Couldn't they just simply call it phase?
Hi Ralf, this is something I had been looking for for a while. Thanks a lot and my vote for you. Cheers Edgar P.S. Just wondering how they define their terminolgy at COMSOL. Couldn't they just simply call it phase?
