Different results on Probe Plot and Surface Plot
I'm trying to model a polymer insulator on electrostatics module and it's been working fine until I decided to add a pollution layer on top of polymer part. I have a boundary probe along leakage distance and obviously pollution layer should increase the es.normE value along the surface. When I take a look at surface solution it looks much higher than clean condition, there's about a 50% increase in es.normE value but the probe plot states that it has decreased, which is pretty much impossible. Is the boundary probe averaging two solutions next to it? That's the only thing I can think of, because now the outer side of boundary has a much lower es.normE since water has higher relative permittivity than air. How can I solve this problem?
Edit: I managed to confirm that the results are indeed different by using max/min surface plotting, Probe Plot's max value is 11.32 kV/cm but Surface Max/Min Plot's max value is 23.56 kV/cm, although my probe is on the same surface.
This is what I'm talking about, electric field norm distribution has a max value of 4.03 but max value function gives me 5.34, how is this possible and which one is correct?
https://puu.sh/yLKXZ/2190a70032.png
0 Replies Last Post Dec 22, 2017, 3:44 a.m. EST
Hello Salih Kızıldağ
