Apr 1, 2011, 7:45 a.m. EDT
design intersecting cylinders, then make an "union" with "imprints" and a "split", then remove any entity needed
Apr 8, 2011, 2:28 p.m. EDT
Dear sir,
I designed the intersecting cylinders,then united both and created imprints. But I couldn't remove the boundaries(appearing inside the domain of the other cylinder) of the penetrating part of one cylinder on the other.So kindly suggest me how to do that..
thanks
SM Ananth
Dear sir,
thanks
SM Ananth
Apr 8, 2011, 4:12 p.m. EDT
I'm not sure I have managed what you want, and 3.5 is getting old and complex, once used to v4 ;)
I made a 3D model (no physics), added a workplane and draw a circle, that I revolve as an U pipe, then I draw/define another straight cylinder that intersects the U pipe and enters into the U pipe volume, without going through, I then do an union Compose object of the U pipe and the cylinder, but KEEPING the interiour boundaries. Then perform a split to obtain 3 volumes, you the recompose the U pipe with it's hole and the cylinder part with an Union (this time DO NOT KEEP the interiour boundaries) you have now two items. You might delete the remaining straight pipe and you end up with the U pipe and the boundary section.
Is this what you wanted ? the annoying thing, I cant remember (if even possible) how to back up one step, when you do something wrong in V3.5
Jun 23, 2013, 1:18 a.m. EDT
Hi All,
I started using the software. I am almost done with the geometry however I have some problems defining my boundary conditions. Basically, I have a cross junction geometry. I am using a syringe pump to enter the fluid from right path and using another pump to suck the liquid from the left hand path. My down path is closed and the upward path is open to air. Can anyone tell me what is the best condition for the inlet and outlet which can simulate the performance of the syringe pumps (Specially about the suction part)? Also, could you please help me about the boundary condition of the upward path which is open to air?
Amir
Hi All,
Amir
9 years ago
Oct 1, 2016, 7:57 a.m. EDT
Can you explain how to give suction condition in rotating two concentrate sphere.
Thank you.
Thank you.
