optimization error
I try to use optimization tool
but I get the error message as below.
Failed to find a solution for all parameters,
even when using the minimum parameter step.
The computed plastic multiplier is negative.
Geometry: geom1, Domains: 7-19
Failed to evaluate variable.
Variable: comp1.solid.Fiil33, Defined as: comp1.solid.Fpi33
Variable: comp1.solid.Ji, Defined as: 1/(comp1.solid.Fiil33((comp1.solid.Fiil11comp1.solid.Fiil22)-(comp1.solid.Fiil12*comp1.solid.Fiil21)))
Variable: comp1.solid.Sl22, Defined as: comp1.solid.Ji((comp1.solid.Fiil21(((((comp1.solid.D11comp1.solid.eel11)+(comp1.solid.D12comp1.solid.eel22))+(comp1.solid.D13comp1.solid.eel33))comp1.solid.Fiil21)+(comp1.solid.eel12(comp1.solid.D44(2comp1.solid.Fiil22)))))+(comp1.solid.Fiil22((comp1.solid.eel12(comp1.solid.D44(2comp1.solid.Fiil21)))+((((comp1.solid.eel11comp1.solid.D12)+(comp1.solid.eel22comp1.solid.D22))+(comp1.solid.eel33comp1.solid.D23))*comp1.solid.Fiil22))))
Expression: d(((-comp1.solid.Sl11test(comp1.solid.el11)-2comp1.solid.Sl12test(comp1.solid.el12)-2comp1.solid.Sl13test(comp1.solid.el13)-comp1.solid.Sl22test(comp1.solid.el22)-2comp1.solid.Sl23test(comp1.solid.el23)-comp1.solid.Sl33test(comp1.solid.el33))comp1.solid.d)*(dvol),{test3})
Failed to evaluate Jacobian of expression.
Expression: ((-comp1.solid.Sl11test(comp1.solid.el11)-2comp1.solid.Sl12test(comp1.solid.el12)-2comp1.solid.Sl13test(comp1.solid.el13)-comp1.solid.Sl22test(comp1.solid.el22)-2comp1.solid.Sl23test(comp1.solid.el23)-comp1.solid.Sl33test(comp1.solid.el33))comp1.solid.d)*(dvol)
Returned solution is not converged.
how can I modify the model?
Thank you
0 Replies Last Post Feb 1, 2018, 9:47 p.m. EST
Hello DoWon Heo
