Integrating global variable over parameter values
Hi all,
I'm simulating a solar cell having the wavelength go through different parameter values, and I have a global variable which is the absorbed spectral irradiance (as a function of the wavelength). I want to integrate this over all the wavelengths, to get the absorbed irradiance. So basically COMSOL is able to make the graph, but how do I get the area under it? I tried to use the quad operator, but it doesn't work. I'm even considerring splitting the area under the graph into rectangles, but COMSOL must be able to do it. I want to do this inside COMSOL, without having to use MATLAB.
Oh, and for some reason my file is 69 Mb, seems like it is too big to upload.
Erik
1 Reply Last Post Apr 7, 2011, 9:25 a.m. EDT
Posted: 1 decade ago Apr 7, 2011, 9:25 a.m. EDT
I not sure any longer how it worked in 3.5 (or even if it was possible without using matlab).
In V4 you export the value to a table and sum it up therein (inside COMSOL)
Hi I not sure any longer how it worked in 3.5 (or even if it was possible without using matlab). In V4 you export the value to a table and sum it up therein (inside COMSOL) -- Good luck Ivar
