6 years ago
Mar 6, 2018, 9:38 a.m. EST
This is very important issue I hope someone would answer you.
6 years ago
Mar 13, 2018, 5:18 a.m. EDT
Perhaps you could set the incident boundary condition to the line which is the entrance of your nano-particle area. Then you could set your pointed boundary condition to the line which is the exit of your nano-particle area. And then to adjust the EM equation to the specific s area.
Hope that could help you.
Best
Fanfei Meng
Best
6 years ago
Mar 13, 2018, 12:59 p.m. EDT
Dear Sir/Madam,
Thank you very much for your reply.
The problem is that when i use scattering boundary conditions, the transmission disappears from the (results) menu. That means, i cant calculate the transmission from the scattering boundary condition. I must use PORTS to be able to calculate the transmission.
Moreover, even if i use the scattering boundary condition, no transmission occurs, the wave cant propagate through any shape of ports that i've designed before.
Thank you very much for your reply but still my problem is not solved. i really need other opinions please.
Thanks in advance.
Yours sincerely.
Dear Sir/Madam,
Thanks in advance.
Yours sincerely.
