Jeff Hiller
COMSOL Employee
7 years ago
Mar 2, 2018, 8:33 a.m. EST
Updated:
7 years ago
Mar 2, 2018, 8:34 a.m. EST
Did you remember to pass time as an argument to the function when you call it?
wv1(t)
Jeff Hiller
wv1(t)
7 years ago
Mar 2, 2018, 9:46 a.m. EST
Hello Jeff!
Thank you for your prompt answer.
I changed a bit my geometry and integrated a Coil to generate the magnetic field. (I got rid of the magnetic field replacing the Magnetic Insulation Boundary).
I had the same trouble when I write wv1 in the Coil current: COMSOL did not know this variable :(
I've tried passing the time as argument and writing wv1(t) in the Coil current but still got into trouble: COMSOL said there is an issue with the Units :(
Then I created an analytic function such as: an1(t) = 0 + wv1(t)
And now I can associate it with the coil current!!! COMSOL accepts it as the Coil current :)
I will go further and try to apply it on an Magnetic Isolation boundary replaced by a Magnetic Field from an1(t).
David
Hello Jeff!
David
7 years ago
Mar 2, 2018, 12:06 p.m. EST
Hello Jeff!
I tried to apply the analytic function an1(t) on the Magnetic Isolation replaced by "Magnetic field" and it works! I wrote an1(t) in the Hx coordinates.
Strangely it does not work with the waveform function wv1(t).
David
Hello Jeff!
David
