Planar Spiral coil, Can not define my output.
Posted Mar 12, 2018, 11:01 a.m. EDT Low-Frequency Electromagnetics, Modeling Tools & Definitions, Studies & Solvers Version 5.3 1 Reply
Hello all,
I am trying to solve for the B-field produced by a planar spiral coil on a diamond substrate. I am following along with a tutorial provided by comsol, "Modeling of a 3D inductor", but I have run into an issue. When I define my coil domain output, Comsol keeps returning the boundary I select is "not applicable". Oddly enough the same thing happens when I load in the 3d inductor example. The simulation will run and solve, but the results seems to indicate nothing is happening. I suspect my coil is not defined right and the current is not applied during the simulation. I attached my file. I was wondering if someone could try and find out why my output is not applicable and why I return no results.
Thanks in advance, Sami
