a quesion
how to express the function at certain point?
"here I don't mean the postproceesing'
1 Reply Last Post Apr 28, 2011, 8:19 a.m. EDT
Posted: 1 decade ago Apr 28, 2011, 8:19 a.m. EDT
do you mean to get in global variable the temperature of a "hard point" of your geoemtry ? if yo make a coupling inteegration operator on points, select the point, and in your equation call intop1(T) for the temperature. An integration in 0D means sum, and the sum of one point is the value at the point itself. This works also so in 3.5
Hi do you mean to get in global variable the temperature of a "hard point" of your geoemtry ? if yo make a coupling inteegration operator on points, select the point, and in your equation call intop1(T) for the temperature. An integration in 0D means sum, and the sum of one point is the value at the point itself. This works also so in 3.5 -- Good luck Ivar
