Flow domain only with inlet without outlet
Posted May 14, 2018, 9:35 a.m. EDT Fluid & Heat, Chemical, Computational Fluid Dynamics (CFD) Version 5.3 0 Replies
Hi all,
I am relatively new at using comsol and ı have got a problem. I would like to simulate ozone's diffusion in the air. My model consists of Turbulent flow and Transport of Diluted Species modules. There is a domain which is filled with air at the beginning. Then ozone is supplied to the domain for 3 minute. In the meantime, only inlet boundary condition is used and outlet is not used. I haven't found out any model to similar this in Comsol model library. I got "Failed to find consistent initial values" error. I think this is due to unknown pressure field so ı used "pressure point constraint". However, the same error is continued.
Can somebody help me? i would appreciate. Thanks
Hello Ozay A.
