Critical Buckling Load
Posted May 4, 2011, 6:25 p.m. EDT Structural Mechanics Version 3.5a 2 Replies
I am new to Comsol and am trying to measure the critical buckling load for a beam.
I started with 2D Euler (In-Plane Euler Beam), draw a rectangle (40nm by 1.2um), fix the bottom and apply a downward load to the top, put in material properties and beam thickness (40nm), mesh and solve. (sometimes constrain points on the top of the beam so the beam acts as a fixed/pinned with no movement in x, only y)
A few questions:
Will increasing the load cause the beam to buckle in this analyse?
How can I plot a load vs displacement to find the critical load?
Do I need a slight side load or will the slight variation in the mesh be enough?
The plan is to see how the number compares with basic theory and then make the model more complicated. So far I have seen the eigenvalue shapes but have no idea on how to get the critical load out.
Thanks in advanced,
A few questions:
Thanks in advanced,
2 Replies Last Post May 5, 2011, 2:36 p.m. EDT
