Adding surrounding air/ambient effect in coupled HT and SPF physics
I have a irregular block with pipe flow within. Water is flowing through the pipe and the block surface is subjected to certain heat flux. I have successfully coupled these two physics (laminar flow and heat transfer in solids) together using non-isothermal flow node.
However, I need to study the effect of cooling the ambient air is having on the block. I made a larger block as the air domain. But when I assign this air domain in the previous laminar flow node(spf1), I was unable to assign inlet/outlet to the pipe within the block. And when I included the air domain in the first heat transfer node (ht1), the heat flux I assigned on the block becomes 'not applicable'.
Can someone point out how I should achieve coupling everything (including heat transfer and laminar flow in air, and ht and spf in block +pipe) together?
1 Reply Last Post May 28, 2018, 2:17 a.m. EDT
Yara Soares COMSOL Employee
Posted: 7 years ago May 28, 2018, 2:17 a.m. EDT
Dear Pei Yi,
If you have an Access Account and access to an active COMSOL license, I would suggest sending your question to support@comsol.com for a swift reply. If you don't have access to a license, please contact me and we can discuss the possibility of a trial version.
Met vriendelijke groet, Best regards,
Yara Soares
COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212
www.comsol.nl | yara.soares@comsol.com
Dear Pei Yi, If you have an Access Account and access to an active COMSOL license, I would suggest sending your question to support@comsol.com for a swift reply. If you don't have access to a license, please contact me and we can discuss the possibility of a trial version. Met vriendelijke groet, Best regards, Yara Soares -------------------------------------------------------------------------- COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212 www.comsol.nl | yara.soares@comsol.com -----------------------------------------------
