Interfacing Piezoelectric Device with Electric Circuit
Hi, I am trying to model a piezoelectric device and interface it with the electric circuite interface. The piezoelectric material should create a voltage, between GND and a Terminal which then should be connected to a resisitor. This should lead to a current through the resistor which I want to simulate.
To demonstrate it here I use the piezoelectric tube example from comsol. I added an electric circuite physic and tried to interface it in the before mentioned way, but as soon as I connect the resistor, the electric potential on the terminal goes to zero and the only measureable electric potential is inside the piezo-material. Is there something I am missing? Like conductance through the material or some coupling inbetween the interfaces?
Looking forward to any form of idea or help! Best regards, Matthias
2 Replies Last Post May 25, 2018, 5:07 a.m. EDT
Posted: 7 years ago May 25, 2018, 4:48 a.m. EDT
The stationary condition of any loaded piezoelectric circuit must be a zero current and thus zero voltage across the load. You must conduct a time dependent or frequency domain study to see a current or voltage across the resistive load. The simple physical reason behind is energy conservation.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
The stationary condition of any loaded piezoelectric circuit must be a zero current and thus zero voltage across the load. You must conduct a time dependent or frequency domain study to see a current or voltage across the resistive load. The simple physical reason behind is energy conservation. Cheers Edgar
Posted: 7 years ago May 25, 2018, 5:07 a.m. EDT
Actually this was it! Thanks a lot!
