Linking the Thermodynamic Properties Database with the heat transfer module
I want to club thermodynamic properties package with heat transfer module for adsorption of CO2 on porous materials. I want to take properties of CO2 from this package because if take default values of CO2 from comsol material library (specifically density) , the simulation results into lots of errors.
is this possible to link these two things?
for reference check the link/
https://www.comsol.com/release/5.3a/chemical-reaction-engineering-module
1 Reply Last Post Jul 6, 2018, 4:23 a.m. EDT
Hello GAUTAM GAUTAM
Posted: 7 years ago Jul 6, 2018, 4:23 a.m. EDT
Hello Gautam,
this is possible, see also https://www.comsol.com/blogs/calculating-thermodynamic-properties-for-liquids-and-gases/
Also have a look at the engine coolant properties example in the application library.
Regards, Linda
Hello Gautam, this is possible, see also https://www.comsol.com/blogs/calculating-thermodynamic-properties-for-liquids-and-gases/ Also have a look at the engine coolant properties example in the application library. Regards, Linda
