assigning volumatric shrinkage as initial stress/strain condition
I have a simple structure consisting of two layers. One layer undergoes volumetric shrinkage. The goal is to find residual stress due to this shrinkage. I would like to assign volumetric shrinkage as initial stress/strain condition between these two layers. I would appreciate if one can tell me how to do that in comsol 4?
Susant
4 Replies Last Post May 9, 2011, 2:46 p.m. EDT
Posted: 1 decade ago May 7, 2011, 6:46 a.m. EDT
Have you checked the Model library Thermal structure interaction Layered plate model, I believe that is the most proper way to do it, as correct tensor values for initial stress-strain are not that obvious to define
Hi Have you checked the Model library Thermal structure interaction Layered plate model, I believe that is the most proper way to do it, as correct tensor values for initial stress-strain are not that obvious to define -- Good luck Ivar
Posted: 1 decade ago May 9, 2011, 1:23 p.m. EDT
Hi Ivan,
Thanks for your reply. In my problem, the volume shrinkage is assumed to take place due to chemical reaction at room temperature i.e. there is no stress free temperature associated with it. The system is at room temperature.
Susant
Hi Ivan, Thanks for your reply. In my problem, the volume shrinkage is assumed to take place due to chemical reaction at room temperature i.e. there is no stress free temperature associated with it. The system is at room temperature. Regards, Susant
Posted: 1 decade ago May 9, 2011, 1:25 p.m. EDT
Hi Ivar,
Sorry about mispronouncing your name.
Susant
Hi Ivar, Sorry about mispronouncing your name. Regards, Susant
Posted: 1 decade ago May 9, 2011, 2:46 p.m. EDT
Hi Suant
I agree you do not need T changes, other physical phenomena that are libnked to stress buildup could be used the same way, It's "just" thatCOMSOL example is for T, but it can be adapted to any other relevant process.
My remark comes from the fact that I have never really managed to sort out the correct tensor values to give to the stress strain cases for initial loading, when we talk of anisotropic or non linear materials, I find it much easier to load udner "realistic" conditions
Hi Suant I agree you do not need T changes, other physical phenomena that are libnked to stress buildup could be used the same way, It's "just" thatCOMSOL example is for T, but it can be adapted to any other relevant process. My remark comes from the fact that I have never really managed to sort out the correct tensor values to give to the stress strain cases for initial loading, when we talk of anisotropic or non linear materials, I find it much easier to load udner "realistic" conditions -- Good luck Ivar
