May 10, 2011, 1:32 p.m. EDT
indeed simple (check the doc) or try out:
a) Results add-select a 1D plot group node, add a Line plot, select an edge(s), define your formula plot
b) select the Data Set, add a cut line or an edge data (sub)set node, define its source data set, add a 1D plot group node, select the corresponding line data set, add a line plot node, write your formula and plot
May 11, 2011, 5:20 a.m. EDT
Hi Ivar,
I know how to plot a formula along a line, my problem is with the formula : gradient of a scalar field (pressure) along a line in a 3D geometry.
Guillermo
Hi Ivar,
Guillermo
May 11, 2011, 10:27 a.m. EDT
Sorry I misunderstood you, well if p is a dependent variable normally px is defined (sometimes pxx second derivative too, depends on the shape element used/selected. Check the COMSOL equations if you see the definition of px,py,pz
May 11, 2011, 10:43 a.m. EDT
Indeed px, py and pz are defined (well, since its on the boundary I can use dtang() operator).
This is a start, the problem then is to determine the correct direction of the 3D line, wich is complicated to compute manually.
Guillermo
Guillermo
May 11, 2011, 11:24 a.m. EDT
the edge normal direction are the ...ny,...ny,...nz, or use the boundary coordinates
