Henrik Sönnerlind
COMSOL Employee
7 years ago
Jun 20, 2018, 1:51 a.m. EDT
Updated:
7 years ago
Jun 20, 2018, 1:52 a.m. EDT
Hi Shashank,
See the answer in the comment field in https://www.comsol.com/blogs/submodeling-how-analyze-local-effects-large-models-2 .
Henrik
Henrik Sönnerlind
COMSOL
Hi Shashank,
See the answer in the comment field in .
Henrik
7 years ago
Jun 20, 2018, 9:02 a.m. EDT
Hi Henrik:
Thanks a lot for your response.
Shashank
Hi Henrik:
Shashank
7 years ago
Jun 20, 2018, 8:44 p.m. EDT
Hi Henrik:
In reference to my earlier query, I created a submodel of the cylinder and used general extrusion operator to transfer results from the global model to the submodel (cylinder) and validated the results.
I am working on a poroelastic model and want to use the results of the submodel as an intial condition for another component with the exact same geomtery (same cylinder as in the submodel). I tried to create another general extrusion operator in the submodel and use it to transfer results from the submodel to this new "component".
However, I am getting an error "Extrusion coupling operator interpolation failed for at least one point: no source point found". Following this error, there are a number of destination coordinates.
I was wondering if this error is because I am using general extrusion operator from the submodel to transfer results to a geomtery with the same dimensions? If yes, is there a work around to use the results of a submodel as an intial condition for the same geomtery?
I look forward to hearing your comments.
Shashank
Hi Henrik:
Shashank
Henrik Sönnerlind
COMSOL Employee
7 years ago
Jun 21, 2018, 9:25 a.m. EDT
Hi Shashank,
There is no obvious reason for your problem here; what you describe sounds OK.
You can experimernt with the settings in the Advanced section of the General Extrusion. By setting Use NaN when mapping fails you can see where the mapping fails (it will be not be drawn in a plot).
Henrik
Henrik Sönnerlind
COMSOL
Hi Shashank,
You can experimernt with the settings in the **Advanced** section of the **General Extrusion**. By setting **Use NaN when mapping fails** you can see where the mapping fails (it will be not be drawn in a plot).
Henrik
